PLEASE HELP, how do i safely remove my front springs?
Old Jun 10, 2008 | 03:07 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Im trying to replace my lower arm bushing and i got it all figured out, except how do you safely remove the front spring, I am going to go pick up a spring compressor, but will it be easy to put it on and compress the spring while its still in the car?
I have the car suspended and the A arms are floating, but still pretty good tension on the front springs. Any advice would be GREAT as im trying to do this project sooner rather then later. Thanks
Old Jun 10, 2008 | 03:49 PM
AmorgetRS's Avatar
Re: PLEASE HELP, how do i safely remove my front springs?
Run a chain through the spring, put a jack under the A-Arm, unbolt the shock. Slowly let jack down and the spring tension will be released. I've never used a spring compressor to install or remove sorings in a Thirdgen.
Old Jun 10, 2008 | 03:52 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Put car on jack stands ( not under A-Arms), so front wheels are off the ground, use your internal spring compressor on spring, when you have some of the tension off the spring, use a jack under A-Arm, apply some pressure on A-Arm with jack. Either, disconnect from ball joint or from the strut. Make sure you disconnected the sway bar, use the jack to slowly lower the A-Arm until the spring will come out.
Old Jun 10, 2008 | 07:24 PM
Engine: V8 350 ci
Well I put the internal spring compressor, but i cant quite get use of it due to the fact the long rod on the compressor kept getting stuck at the top of the spring area due to insufficient room, so i tried putting the compressor lower and the bottom hooks UNDER the a arm, it seems to work, but the shock never became loose, but it did take some of the tension off,
you what I'm getting from the responses if just put a jack under the a arm and slowly lower it down once ball join crown nut is removed? sounds dangerous, im almost tempted to abandon this mission.
Old Jun 10, 2008 | 07:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Use a 4" pipe nipple on the compressor or it'll never work. I simply unbolt the strut from the spindle and lower--and as Amorget mentions (unless you have a dental plan) use a chain.
JamesC
Old Jun 10, 2008 | 07:34 PM
Engine: V8 350 ci
JamesC
okay..what is a 4" nipple pipe? I assume some kind of extension for the wrench or am I way off? And how does this help? I didn't have any problems tightening the bolt except that I tightened it so much it hit the top of the spring plate?
Old Jun 10, 2008 | 08:48 PM
JamesC's Avatar
A short length of pipe which slips on the compressor's threaded rod, effectively shorting it.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
3rdgenparts
Aug 8, 2015 07:09 PM
