6 1/2 backspace on prostars
Old Jun 14, 2008 | 03:13 AM
2bfeard's Avatar
Car: 1986 iroc
Engine: 350 .060 AFR HSR XFI280
Transmission: transgo 700r4
hello i would like to know if a set of 15x10 with a 6.5" backspace would fit my 86 iroc with disk brakes? if so what size tires would i be able to fit and finally wat would be the difference if i were to get 5.5 backspace instead. thanks!
Old Jun 14, 2008 | 11:11 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 6 1/2 backspace on prostars
the 6.5" of bs would tuck the wheels nicely int he wells, although you will most likely need to do some inner fender mods to make them clear.
Old Jun 26, 2008 | 09:19 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
the last i remember reading was that a 15x10 with a 5.5 b/s was about the biggest we could run without "massaging" not to say you couldn't do a little "work" on the wheel wells, but i'd be closely checking the placement of the shocks vs. the rims vs. the wells before buying those rims. maybe someone who has done that rim will chime in.
i'd like to hear myself!
Eric B
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Sep 29, 2015 10:18 PM
romcjr
Sep 17, 2015 05:18 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
