Sway Bar
Old Jul 5, 2008 | 11:43 AM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Sway Bar
Besides actually measuring, how can I determine what size sway bar is on Camaro? Is there an RPO code that says? I went out to Pull A Part looking around for the heck of it, and started thinking a bigger sway bar would be good to have.
Old Jul 5, 2008 | 11:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Sway Bar
Wrap a string around it in a couple of places and measure, or simpler put a cresent wrench around it and measure the jaws. The hollow 36mm bar (and the hollow 34, I assume) have small drain holes near the end links.
JamesC
Old Jul 6, 2008 | 06:44 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Sway Bar
To confirm what confirm what JamesC wrote, yes, all hollow 34mm sway bars will have a small drain hole on the end.
I wouldn't recommend going off of an RPO code, especially at a U-Pull It. The previous owner may have swapped in a different diameter bar and you would never know without measuring it. I have a caliper that I alwasy bring to the junkyard for stuff like that.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
