Front end re-build
Old Jul 8, 2008 | 05:09 PM
cdacda13's Avatar
Car: 1992 Camaro
Engine: 5.0L TBI
Front end re-build
I've decided to finally fix the front end of my Camaro. I've got most of the parts lined up but want to make sure I'm not missing anything. So, please check my list
Moog Front End Rebuild Kit
Energy Suspension Hyper-Flex Complete Bushing Set
Front 32mm & Rear 21mm Sway Bar Set (Solid)
Edelbrock 87-92 Camaro/Firebird V8 w/ TPI Or TBI Strut Tower Brace
Tubular Steering Brace (Wonder Bar)
KYB 4 GR-2 STRUTS
Tubular Sub-Frame Connectors (Spohn)
Any special items I'm missing?
Still looking for the right springs though. I do not want to drop the car, I already bottom out enough because I live in a area thats very hill-y. Any recommendations?
One last question, how hard is it to do springs? I've done them before, but that was on my friends accord( )
Car will be a daily driver until I finish the engine, then will be a street/strip car.
Thanks for the help guys.
Old Jul 9, 2008 | 04:59 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Re: Front end re-build
KYB 4 GR-2 STRUTS
i did all mine a while ago, umm did you get tie rod's? and tie rod sleeves? thats a big one, and ball joints. dont really know what you mean by "front end rebuild kit"
dont forget A arm bushings either.
as far as the coils, the fronts arent that bad but be careful lowering the a arm cuz they will shoot right out. the rear are easy if you lift the car on its frame and have no load on the rear, you can literally yank out the coils and put them in as well. the rears are easier than the fronts. but if your doing a front end rebuilt, that would be your best chance to swap the coils then.
Old Jul 9, 2008 | 07:35 PM
cdacda13's Avatar
Car: 1992 Camaro
Engine: 5.0L TBI
The front end kit from Moog includes:
  • Moog Centerlink
  • Moog Idler Arm
  • Moog Inner Tie Rod Ends (Qty. 2)
  • Moog Outer Tie Rod Ends (Qty. 2)
  • Spohn Extreme-Duty Tie Rod Adjusters (Qty. 2)
  • Ball joints (2)
Old Jul 9, 2008 | 07:57 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Moog replacement springs will do fine. You can get them through Summit or O'reillys (might be local pickup) for a fair price. There's a federal mogul site that will cross reference their part numbers to the vehicle year/model. Or try a search, there was a recent thread where several posters recommended some moog spring part numbers. Try:
https://www.thirdgen.org/forums/susp...ht=spring+moog
Old Jul 11, 2008 | 09:21 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Don't forget the upper strut mounts!!!!!!!! And get the ball joints replaced while you have the a arms off the car.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
