Which Torque arm Bushing do I need?!?!?!!?
Old Jul 22, 2008 | 09:22 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
I'm trying to order this ASAP. Summit lists two possible bushings
One that says
Fits bushing with steel lips facing away from the driveshaft.
and one that says
Fits bushing with steel lips facing toward from the driveshaft.
What the heck are they talking about. I don't see any lips on anything. I see points where the bushing is mounted to the Clam Shell bracket thing but thats about it.
Any help would be greatly apreciated as I'm trying to put my Motor/Trans in this weekend.
I figured it out. Here it is if anyone else ever needs it.
Old Jul 23, 2008 | 12:42 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Which Torque arm Bushing do I need?!?!?!!?
The one on the left is the one your going to need,
you could have just looked under your car?
Old Jul 23, 2008 | 06:53 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
How the heck did you know that without looking?
I wasn't sure what they mean't by steel lips away/toward from Driveshaft. When I found that picture (edited into my first post) I realized what I had.
Old Jul 23, 2008 | 09:52 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, 1984 and earlier was the right style, 1985 and later is left style
Old Jul 23, 2008 | 03:01 PM
FueledSoul's Avatar
im just that good
Old Jul 23, 2008 | 08:59 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
This is good to know since I plan on replacing mine. Half the bushing is hanging out of where it should be... I guess the rubber is bad.
</div>
Nervous2
Oct 8, 2015 10:53 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
