Suspension build Q
Old Jul 26, 2008 | 02:06 AM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
Suspension build Q
Should i 8 pt roll bar be installed after all other suspension upgrades so the stance/height sits right?
Old Jul 26, 2008 | 08:28 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Suspension build Q
If your going to go faster than 135 in the quarter or quicker than 9.99. Otherwise its a waste of money
Old Jul 26, 2008 | 10:02 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
roll bar is needed at 11.49, cage is 10.99.. 9.99 you need a 12 point cage??(not to sure) and a license..
i had my 10point cage in the car when it was running 12's.. needless to say, it has made me feel better in some situations.. for example, going sideways at the 1/8th at over 90mph..
as for doing it before suspension, it doesnt matter.. all in all, it helps bring rigidity to the "frame".. could be an key part it gauging suspension upgrades since the chassis wont flex..
Old Jul 26, 2008 | 10:18 AM
Stephen's Avatar
Car: 87 GTA
Cages aren't only for drag racing.
For a stiffer chassis that controls the suspension better for autocross or a road course, they are a good thing to have, despite not having 9-second 1/4 time times.
Old Jul 26, 2008 | 05:30 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Yea it would stiffen up the frame quite a bit. I really don't think it would be that necessary to put in a 8 pt cage.
Old Jul 28, 2008 | 02:51 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
A little off topic, but how much would a 4 or 6 point cage cost to have made and installed? I think an 8 point is a little over kill for something that would still be used as a street car.
</div>
J-money
Jan 4, 2019 09:45 AM
Jorlain
Oct 8, 2015 01:57 AM
R13_Braz
Sep 18, 2015 05:00 PM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
