Need help tourqe arm broke
Old Jul 26, 2008 | 03:16 PM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
I went to the dragstrip last night, and on my second pass I heard something snap and slap my floor board.
I crawled under the car today. To my understanding the torque arm was not originally mounted to the crossmember. The previous owner tried to do so, and the bolts sheered right off. There are no bolts holding the bracket to the crossmember, and there is one bolt holding the torque arm to the bracket.
Would using higher strength bolts fix this issue?
Is there a cheap way to fix this and get better performance?
A picture of the front part of the bracket with the two bolt holes that mount to the crossmember
Picture of the one bolt holding the torque arm
Old Jul 26, 2008 | 08:28 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Need help tourqe arm broke
yea throw that cr@p in the garbage and buy a good one. i went with jegster its 2/3 shorter than stock, tubular, really light and bolts to the tranny tunnel to take the stress off the rear of the trans. BMR, UMI etc make them also but the jegster is the shortest and lightest, a shorter arm increases tire bite
Old Jul 27, 2008 | 12:08 AM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
Thanks for the post, but I am kind of on a budget so I need a temporary fix. I am going off to college so I am now unemployed.
Will I need a new cross member with an aftermarket tourque arm?
My car currently has a short tail th350 so I don't think I could use a tourque arm that didn't bolt to the crossmember.
Old Jul 27, 2008 | 08:24 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
http://www.umiperformance.com/2214?category_id=114
http://www.spohn.net/shop/1982-1992-...nsmission.html
looking at about 400 bux from UMI or Spohn for a crossmember mount arm
http://www.jegs.com/i/Jegster/550/40097/10002/-1
this is another option, a little cheaper, and a shorter arm which can help increase wheel bite.
Old Jul 27, 2008 | 09:45 AM
g_nutts's Avatar
Car: 88 camaro, 05 silverado
Engine: 383 sbc
Transmission: stock t-5
Axle/Gears: 10 bolt, 4.11s
Yeah, unfortunately what you have on your car now will never hold up on the dragstrip. It doesn't matter if you put stronger bolts in it or not, the geometry in the rear suspension needs to be right or nothing is going to work. I went with the jegster arm too, its on the cheaper side compared to spohn or other torque arms. Here's a pic of mine.
http://i51.photobucket.com/albums/f3...OEYSCAR002.jpg
Old Jul 27, 2008 | 09:01 PM
Car: 87 TA clone
no tempary fix sry... its not good driving with wat u got now.
g_nutts... u got any more pics?? i wanna see where it bolts to the floor bc im gona tie in my 8pt roll cage to it so it adds more rigidy. how far back does it bolt in the tunnel if u were looking at it from the inside of the car at the tranny tunnel? how far from the back of the center consol?
Old Jul 28, 2008 | 04:21 PM
406z's Avatar
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
Thanks for all the help. All the products listed and advice was great. I won some sphon lca's and poly bushings on ebay a week ago. So I will keep my eye peeled for a deal on one of those peices.
I looked at the bracket that was used and my stock crossmember both are bending a little bit. This explains my 1.9 second 60 foots. I am going to bolt it back together till I get the money for the ourqe arm.
Old Jul 28, 2008 | 05:16 PM
Guest
Guest
Posts: n/a
It looks like its solidly mounted, which will eventually bend and break everything in sight.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
