could it be??
Old Jul 27, 2008 | 08:32 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
could it be??
I have a popping noise in my suspension. The inner and outer tie rod ends, ball joints, strut mounts, and sway bar bushings have been replaced in the last three to four years. I replaced the driver's side a-arm bushings yesterday, and I still have noise that doesn't sound like it's coming from the driver's side. I think it may be one of the steering linkages... is this possible? I've always heard that these pieces don't cause noises....
Old Jul 27, 2008 | 08:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: could it be??
is the sway bar hitting the strut?
Old Jul 28, 2008 | 07:01 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: could it be??
It's possibility I'd not considered. I haven't seen any rubbed spots though.
Old Aug 23, 2008 | 08:15 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Re: could it be??
Replaced the a-arm bushings, and I've still got the noises. I'm thinking it might be in the steering linkages (idler arm, pitman arm, centerlink). Could these be causing the noises?
