Different tire sizes for front and rear...
Old Apr 26, 2008 | 07:03 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
How bad will this look?
Front: 235/60-15
Rear: 255/55-15
I can't go wider in the front, because the tires will rub the swaybar, so I'm going to leave those the stock size. Will the rear tires, being 3/4" wider and .03" shorter look bad on the stock 15" wheels?
The state says I need new rubber, since I've had the current ones on there since 1996...
Old Apr 26, 2008 | 07:20 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: Different tire sizes for front and rear...
think i'd try to go 275/55 on the back. seems to look pretty good even on a 7 inch wheel.
don't think you or anyone else will notice that .03.
my mom has you beat. her 70k mile 86z JUST got rid of the stock OEM gaterbacks
talk about it riding like a new car again.
Old Apr 28, 2008 | 09:52 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I personally wouldn't go any wider than the 255s on the 15x7s. And I don't think it would look bad, but I think you can find 255/60s that will be closer. It will however throw off the speedometer slightly and you won't be able to rotate the tires.... so make sure your allignment is good.
Old Apr 28, 2008 | 10:13 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Welcome to reality fella's, good luck finding the elusive 55 series tire eh?
And yea, different front/rear sizes is pretty common, and looks great.
Old Apr 28, 2008 | 01:31 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wow.... I just realized how long you guys have had the same tires... I've had my car for a little over 4 years, and I've have 2 sets of Cooper Cobras (first set was on the car when I got it, and then replaced them with the second set), one set of BFG g-Force Sports in 245/50ZR16, then a set of Bridgestone Potenza G009s (winter tires for the stock wheels), and then my current set of g-Force Sports in 275/40ZR17.
Old Aug 23, 2008 | 10:24 AM
Well, I drive it about 700 miles a year. That might have something to do with it...
Old Aug 23, 2008 | 10:28 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
IMO too wide on a narrow rim is hideous... and yea i have hookups in the tire world and have trouble with the 55's
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
knight72
Aug 10, 2015 09:32 PM
