Pitman arm puller bend in half.......
Old Jul 29, 2008 | 11:21 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I bought a pitman arm puller and the damn thing bent in half.... It wasnt a cheap puller either, not a snap-on but no ebay brand. Anyone else have a problem like this? Why didnt it work! The box is off an S10, just trying to swap my stock arm for that one and it's a pain.
I meant bent in the title...
Old Jul 29, 2008 | 04:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pitman arm puller bend in half.......
Sometimes I think the pitman arms are welded on. . . Heat is helpful. Get a rag and soak it in water, wrap it around the output shaft right where it comes out of the box. This is to keep the internals and the seals cool.
Put the puller on and tighted it up. Then hit the pitman arm with a torch (even a plumbers propane will do). Don't heat the shaft, just on the arm around the shaft. Heat it up and leave it sit for a moment. Then add some more torque to the puller. Some more heat, and wait a moment. Can also hit the pitman arm with a hammer toward the off direction. Not too hard, just enough to shock it a little.
Sooner or later it'll just pop off with a bang while you are standing there wondering what to do next.
RBob.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
