lowering spring help!!!
i just installed the summit lowering springs in my car, and the driver's side is dramatically higher than the passneger's, and they are both higher than i can remember the stock height.
some one had mentioned to me in the past about "indexing" the springs correctly. can some one explain that to me??
i have found this diagram of the front susp, maybe y'all can use that to help me.
i'd appreciate it!
i'd appreciate it!
Re: lowering spring help!!!
indexing the spring is easy. if you look at the a arms in the diagram you have posted...there is a big hole in the center of it with a few smaller holes around that. if you look close there are 2 holes that are very close to eachother....you want to have the end of the coil in the a arm in between those 2 holes. also make sure the rubber insulator that goes on the top of the spring is in correctly. sometimes they move when installing springs and can mess things up.
Thornburg
Sep 12, 2015 10:11 AM
