subframe
Old Aug 9, 2008 | 11:23 AM
tri power's Avatar
subframe
How much trouble is it to change front subframe on 91 camaro? Mine is bent where engine mounts sit on the bottom of frame, looks like someone ran over something.
Old Aug 9, 2008 | 12:20 PM
lewandom's Avatar
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
Re: subframe
the k-member or subframe, the k-member is relitivly easy, you kist take the engine out, the springs out, and take out the A-arms and it is held in by 6 bolts and 2 brackets(the brackets are only in "profromance" cars...eg Z-28, T/A ect.)and the brake line, the subframe is permantly part of the car and can't be removed W/O a torch.
Old Aug 9, 2008 | 01:00 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: subframe
You don't need to take the motor out to remove the k-member, just support the motor so the K-member can be removed
Nervous2
Oct 8, 2015 10:53 PM
tmork454
Sep 29, 2015 06:33 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
