Mevtech questions
Old Aug 9, 2008 | 12:41 PM
discoinferno65's Avatar
Mevtech questions
I am looking into getting new ball joints, tie rod end and tie rod adjusting sleeve. On the PartsTrain website they have MevTech and Moog. Is there anyone out there with expeience with Mevtech who could tell me if its worth trying out or if i should go with the more expensive (but probably won't break in a week) Moog. Also is there anything else i should look into replacing while i'm down there? I've replaced other steering and suspension parts before but not these so input is greatly appreciated. thanks!
Old Aug 9, 2008 | 04:16 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Mevtech questions
You can never go wrong with Moog. But that doesn't mean the other brand is bad. You might as well replace the idler arm and center link while your there! rockauto.com is the cheapest I have found for Moog parts, plus there are discount codes on the board that you can get. There is a whole thread with codes.
Old Aug 22, 2008 | 12:57 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
i got the mevtech, there not to bad, with energy suspension, just make sure u order things 2x cuz their not in pairs like the site says
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
