strut mount spacers
Old Aug 11, 2008 | 03:52 PM
eeeeeefirebird's Avatar
strut mount spacers
so i am lowering my car, and to help compensate i thought about ditching the strut mount retainers and using bolts and spacers to raise the strut mount off of the strut tower app 1". they are steel spacers, and the bolts are grade 5, they only had four grade 8 bolts at the hardware store and i needed six. is this a bad idea? should i go find some grade 8 bolts? the bolts are only 1/4" so they would fit in the strut mount holes, and i couldnt find 5/16" ID spacers or metric spacers, and 3/8" was too big. my camera broke so i dont have any pics. any ideas, thoughts, comments, concerns, all welcome. thanks
Old Aug 11, 2008 | 04:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: strut mount spacers
You may not be interested as they're a bit pricey, but Spohn sells a strut mount that will accommodate a lowered car.
http://www.spohn.net/shop/1982-1992-...ut-Mounts.html
JamesC
Old Aug 11, 2008 | 06:51 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I say don't use the grade 5 bolts. The bolts for your strut mounts are what prevents the struts from poking huge a holes in your hood.
Try finding the correct bolts/spacers/nuts at another hardware store, or I think Spohn even sells the bolts and nuts required for the strut mounts.
Old Aug 12, 2008 | 11:48 AM
spohn sells new strut mount retainers, studs welded to a bracket. the point is i already spent a hundred something on kyb strut mounts a long time ago and they sat, and if i can safely put spacers under them tohave the strut bolt in at closer to the correct height, i want to.
J-money
Jan 4, 2019 09:45 AM
rb85TA
26
Sep 14, 2015 10:29 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
89 formula TPI
Sep 8, 2015 08:00 PM
SG91camaro
Sep 5, 2015 10:27 PM
