new strut question
Old Aug 13, 2008 | 02:41 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
new strut question
ok i have just bought new KYB struts and have a few questions
1. IN the instruction sheet it SHOWS that i have to drill a hole in the strut and drain something out, do i need to do this and why?
2 what are the two bolt sizes for the struts down by the brake caliper? i want to replace them with SS when i put the new ones on
THx
Old Aug 13, 2008 | 03:54 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: new strut question
I have no idea why they want you to drain the strut. I take it this would be the old ones? I can't see doing that to the new ones. Having changed the struts I've never drilled them.
For the bolts: 16mm, about 3-1/2" long, course thread, grade 10.9 (basically grade 8). Nuts are crimped for locking with a large shoulder. Also has a thick washer under the bolt head.
RBob.
Old Aug 13, 2008 | 10:32 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
HI, I don't know why you would drill a no strut but It brings a idea to me. My buddy has a mustang with 90/10 front struts and it pulls the front end up when hes given her. so If I drilled a hole in the stock strut and drained of 3/4 of the oil would it be like a 90/10 or a drag strut?
Old Aug 14, 2008 | 10:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
A little more info on the strut to spindle bolts along with the proper length:
The length is 3" (under head to end of threads).
They are a torque to yield bolt: 125 ft/lb, then 120 deg turn, must exceed 148 ft/lb during the 120 deg turn. Otherwise bolt is bad.
GM states in the '92 service manual to replace the bolts, washers and nuts after each removal.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Apr 25, 2017 07:14 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
