CAN I DO THIS ???
Old Aug 17, 2008 | 04:48 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
CAN I DO THIS ???
this maybe simple , or not . can i swap a entire steering column from an 89rs manual tranny into a 88 s/c auto tranny ? both are tilt , cruise etc. . 88 has the " loose tooth syndrome " and a bad ign. switch cylinder . the 89 is nice and tight with a good ign. switch . the 89 also had vats that i could live without . i'm sure it will fit , but concerned about starting problems . how about it James C , with your vast 3rd gen knowledge you should know . does anyone know ??? please tell me it can be done . thanks .
Old Aug 18, 2008 | 05:32 AM
UNCLE TOM's Avatar
Re: CAN I DO THIS ???
bump
Old Aug 18, 2008 | 12:23 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
yes the column will fit it will bolt right up the vats system is only a wire that you don't have to hook up cause your 88 don't have it. the only thing is the wheel lock for the key is a diff setup. but if you don't mind that then you should be ok.
Old Aug 18, 2008 | 12:45 PM
UNCLE TOM's Avatar
well i felt pretty sure it would work . i guess i just needed someone else to assure me . just got registerd & ins. this morning , can start the swap feeling good about it . thanks ....
