a few questions about jacking the car
Old Aug 23, 2008 | 04:44 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
ok i'm almost done with getting all my new steering components and sway bar bushings and will soon be putting it all on the car, first question is when i want to jack the rear of the car up so i can change out the sway bar endlinks /main bushings where do put the jack/jack stands?. Second, when i do get all the steering components for the front, should i jack the car up from engine cross beam and put the jack stands on the rails? i did a search and got some info but i would like it to be crystal clear for when i do it.
Old Aug 23, 2008 | 07:58 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Re: a few questions about jacking the car
https://www.thirdgen.org/forums/susp...ion-101-a.html
Old Aug 24, 2008 | 12:44 AM
Engine: 350(5.7L)
ok that covers the front end of the car now how about the rear?
Old Aug 24, 2008 | 02:51 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I don't like jacking these cars by the front cross member unless the jack has a good sized saddle on it although I can't get a jack under mine at that point anyway so I use one on each side on the SFCs just behind the front wheels or on the jacking points if there's no SFCs.
I wouldn't use one of those small CT red jacks on the cross member - the car might slide off it.
For the assend I just put a floor jack under the punkin.
Old Aug 24, 2008 | 03:16 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
This is when I was doing the front and rear sway bar bushings and end links.
Usually I would have the rear stands under the axle but to do the bushings/links I had them further forward.
Pretty sure I had a jack under the pumpkin to control the axle height when I was doing this.
That red jack is the type that I wouldn't want to use under the front CM.
Old Sep 8, 2008 | 08:08 PM
eeeeeefirebird's Avatar
it will be easier to keep the car at ride height by putting the jack stands under the axle, or what george said and put a jack under the gears and stands where the lcas bolt to the frame for security.
MustangBeater20
Oct 29, 2022 09:20 PM
B_Dubya
Aug 26, 2015 05:09 PM
mizz0313
Aug 12, 2015 06:45 AM
Amillionoh7
Aug 7, 2015 01:24 PM
