Thinking about lowering my car.. Got a question..
Old Aug 28, 2008 | 04:50 PM
BladeX10's Avatar
Car: 1991 RS v8
How many inches of ground clearance do you have under the lowest part of your car underneath? For those who have lowered there cars.
Old Aug 28, 2008 | 05:59 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: Thinking about lowering my car.. Got a question..
Thats all going to depend on how far you lower it.
And also exhaust setups, engine,trans oil pans.
Traction control devises, ect.
I've dropped my mine about 2" front and 1 1/2" in
rear. Coilover front, Eibach rear.
Top of tires even with fender lips.
4 to 4.5" closest point.
HTH
Later
Old Aug 28, 2008 | 06:11 PM
BladeX10's Avatar
Car: 1991 RS v8
Ive have about 6 inches clearance right now.. Id like to drop it maybe an inch or 2.
Do you have a hard time going over bumps and stuff with 4 inches clearance?
Old Aug 28, 2008 | 07:42 PM
GMLSX's Avatar
Car: 1998 Slow
Engine: Too Small
i lowered my old 85Z with eibach sportlines and was careful over speed bumps...never had a problem with normal roads and holes though...just didnt wanna take a chance on ripping off the exhaust.
if you find a good shop to tuck the exhaust youll be much better off, cuz the stock y pipe hangs low.
Old Aug 31, 2008 | 03:37 PM
jaykar's Avatar
No scraping over speed bumps as I slow down for
speed bumps the same way I would in my other
halfs 10" ground clearance Ford (Exploder)
Actually closest point is the air dam and being careful
not to park to close to store curbs which it doesn't do
to often.
Also if you do lower the car you are going to need to install
lower control brackets to get your LCAs back uo to at least
horizontal.
Later
Old Sep 1, 2008 | 12:14 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I have about 3"-3-5" from the lowest point. I can't remember how many inches I lowered it.
customblackbird
Aug 15, 2021 10:16 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
midge54
Jan 29, 2017 07:00 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
