New Rims & Tires on the way
Old Sep 3, 2008 | 06:14 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Just ordered a Set of the Billet Specialities Street Lite wheels (15x10 & 15x4), along with a set of MT ET Street Radials (275/60/15). I ordered from Larry Hodge Racing .....
$929 for the set of 4 Wheels (Center caps, valve stems, and shipping)
Ray
Old Sep 3, 2008 | 08:56 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: New Rims & Tires on the way
post pics of them mounted up.
what backspacing did you go with in the rear?
Old Sep 3, 2008 | 08:58 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
5.5" backspacing
Old Sep 3, 2008 | 09:13 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Why'd you go with a 15x10 and that backspace if you don't mind? What tire for the front?
Old Sep 3, 2008 | 10:57 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I went with that BS from what I read on here... The front is 27.5/4.5/15
Old Sep 3, 2008 | 11:47 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
LOVE these wheels!! been waiting to see them on a third-gen, PICS!!
Old Sep 9, 2008 | 07:00 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Well Rims and Tires arrived yesterday.... I will work on mounting them on the Car tomorrow, and post some Pictures.
Ray
Old Sep 17, 2008 | 08:36 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Re: New Rims & Tires on the way/ HERE (Pic)
Here is a pic of my new wheels after I visted the track the night before.
Ray
Attached Thumbnails New Rims & Tires on the way-new-wheels.jpg   New Rims & Tires on the way-new-wheels2.jpg
Old Sep 17, 2008 | 08:39 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
This is what is under the stock hood
Old Sep 17, 2008 | 08:41 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
It looks like the rear tires stick out... Is it noticable? Can you get a side shot? If you could, would you go with a different backspacing for the rear? Other than that... They look GREAT!
Old Sep 17, 2008 | 08:44 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
I would go with 6" of back spacing if I could do it again. Here is 1 more Pic of the motor
Old Sep 17, 2008 | 08:58 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looks like fun! What are you running at the track? Is it basically stock with a supercharger?
Old Sep 17, 2008 | 09:36 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
NO Supercharger here!!!! That is a Turbo! Built Block w/ custom cam, Dart heads, HSR intake, T400, 3200 stall, and S475 turbo w/ 4" downpipe. BMR K-member, BMR coilover, Wilwood Drag brakes, Spohn Tq arm, and SLP line lock. Went to track (1/8 mile) for the 1st time after finishing car Friday night only got 1 pass in when the TPS sensor took a dump. Car ran a 7.9 w/ 1.89 60', getting on and off throttle because really lean (14.1 afr).
Ray
Old Sep 17, 2008 | 10:20 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Wow... haha, I was thinking it didn't look like a paxton. Why did you decide on getting a turbo over a supercharger? What should you be running in the 1/4 mile?
Old Sep 18, 2008 | 06:04 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
low 10's
Hotrodboba400
Dec 10, 2019 07:07 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
