Rollcage welded to the floor instead of the SFC's
Old Sep 17, 2008 | 07:29 PM
SpiderViper's Avatar
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
Hey guys Im doing an 8 point roll cage in my car this weekend and I realized that they are supposed to weld to the SFC's which I have, but need to cut away a lot of the floor and redo my exhaust to make them work. Could i leave them out and weld it all to the floor pan? would it be sturdy enough to run 400hp on Drag Radials with my TTops? It does not have to be certified or anything just keep the car from twisting on take off...
Thank you for your time,
~Chris
Old Sep 17, 2008 | 09:29 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Rollcage welded to the floor instead of the SFC's
the roll cages are suppose to be welded to the floor with 6"x6" steel plates supplied in the kits. not suppose to cut the floors to be installed. the plates are welded to the floor where the subframes meet and are spotwelded to the floor pan. for strength
Old Sep 17, 2008 | 09:37 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
Okay so I really don't need the SFC's?
Old Sep 17, 2008 | 09:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Yes. SFC tie the front and rear subframe together. With a unibody car, they are a necessity. A roll bar/cage does help to stiffen the car up a bit but doesn't work the same way SFC do so you need both.
The 6x6 plates need to be welded to the floor. These will provide 2 feet of weld to attach the roll bar tubes to the sheet metal of the car. The tubes are then welded to the plates. The plates can be heated up and formed over the sheetmetal for a better fit and the tubes don't need to be installed directly in the center of the plates.
Old Sep 17, 2008 | 09:57 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
I have read a lot of your post's and you seem to know your stuff lol do you think i would be okay for a few passes at the drag strip with a lioght foot brake launch on drag radials and 100 shot of nitrous? Or should i leave the nitrous out till im rolling?
Thanks so much
~Chris
Old Sep 18, 2008 | 12:58 AM
EvilCartman's Avatar
Car: '82 Z28
What stall converter are you running and how is your nitrous being activated? If the car can stay stuck to the track, nail the nitrous right out of the hole. If it just spins, hit the nitrous later.
Old Sep 18, 2008 | 02:20 PM
Car: 1987 Iroc-Z
Engine: 5.7L SB
Stock Stall converter and the nitrous is on a WOT activation with a power switch to the solinoids in the cockpit so i can hit it when ever... Illl prolly wit till im at about 5mph or so but possibly off the line because of the low stall converter.
Old Sep 18, 2008 | 04:07 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I understand that they are both good to have, but what ways are the functionality of the SFC different from the functionality of the roll bar. I have spohn SFC waiting to be installed and I'm thinking about getting a 6 or 8 point roll bar with swing out door bars. This car is used as my DD, autocross car, and the occasional drag race. I figured the roll bar will be a little better then just SFC for autocross, it will allow a safe way to use a 4/5 point harness, it will allow for future motor builds, and it will provide a race car look. I'm acutally not to concerned about the last one... it comes comes with it. If I had a choice, I would want to get a roll bar built into the car in way where you can keep the stock interior as is and no one would know you have the roll bar/cage ex: the headliner would hide the top of the main hoop.
Old Sep 18, 2008 | 06:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A roll bar/cage doesn't keep the floor/body from flexing, stretching, bending etc. It will add some stiffness but doesn't tie the sheet metal floor/subframe together.
I've had custom weld in SFC since the first day I raced my car. I now have a full cage with a sill bar and still have the original SFC still installed because the cage tubes still don't join the subframes together. The rear subframe is now a back half but there's still no frame other than the SFC connecting the front to the rear.
Old Oct 25, 2008 | 08:04 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
wow geek we pretty much want the same thing with our cars. do u have a cage now?
Old Oct 25, 2008 | 11:14 PM
Car: 1987 IROC-Z
Transmission: TH350
Nope. No roll cage yet... not even a roll bar. My uncle helped me decide to hold off on it since my car is in such good condition and it being all original. Everything I've done to it can be reversed except for the SFC and I have all the original parts. Another reason I'm holding off is because my little 305 doesn't have the power that would make it a requirement.
Instead, I got some more suspension stuff.
Mike
Old Oct 26, 2008 | 12:18 AM
Car: 02wrx/88 rs
well neither does mine but... we are susp cars its never a real requirement unless we are hard core at a track. im wanting to do very similer setup with mine only i have nothing original to keep. its an RS lol i have only driven at one autocross and that killed my old tranny.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
meeklay812
Oct 1, 2015 03:46 PM
