Steering Box Removal Question
Car: 82 Z28
Engine: 327
Transmission: TH350
I'm in the process of removing my steering box, I have everything disconnected with the exception of the box itself. I see the 3 bolts that look like they are bolted in from the backside of the sub-frame, and the bolt on the lower bracket.
My question is, where are the bolt heads for those 3 bolts?
I've done everything from above the car thus far. I tried looking through my fender well and I can't see them.
Any help or pictures would be appreciated.
Thanks in advance
Thanks in advance
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Steering Box Removal Question
If I remember right, there are three in the wheel well and two below. Then you undo the power steering lines going to/from the unit and disconnect it from your steering linkage. I would post pictures but my camera isn't working. I'm thinking I need a new one...
I'll try and get it to work.
Mike
I'll try and get it to work.Mike
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
couldnt have looked too hard.
they are in the driver-side wheel well, ahead of the tire, the may be partially obstructed by the plastic wheel well liner. IIRC one bolt head is hidden a bit by the triangular lower fender support
Car: 85 Z28
Yup, the triangle has to come out to get to 1 or 2 of them. If you trace back across the frame rail where you see the threads coming out from the box, you will get an idea of where the bolt heads are located.
backtothe80s
Sep 5, 2015 12:39 AM
