RaceCraft K-Member and A-Arms
Old Sep 22, 2008 | 02:51 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Received my RaceCraft K-member and A-arms today. My impressions are very good as to the quality of the product. Paint and welds are excellent. It is actually more robust than I thought it would be. In the pictures you well see a piece of 4x7 oval tubing. That will be the drivers side exhaust termination box. The kit comes with the mounting hardware as shown in the pictures. Here are the pictures.
Attached Thumbnails RaceCraft K-Member and A-Arms-racecraft-k-member-003.jpg   RaceCraft K-Member and A-Arms-racecraft-k-member-004.jpg   RaceCraft K-Member and A-Arms-racecraft-k-member-005.jpg
Old Sep 22, 2008 | 02:54 PM
Car: 1989 GTA
Engine: 369 TPI
Re: RaceCraft K-Member and A-Arms
More Pictures.
Attached Thumbnails RaceCraft K-Member and A-Arms-racecraft-k-member-006.jpg   RaceCraft K-Member and A-Arms-racecraft-k-member-007.jpg   RaceCraft K-Member and A-Arms-racecraft-k-member-008.jpg
Old Oct 2, 2008 | 03:33 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
did you get them in yet? any updates?
Old Oct 2, 2008 | 06:25 PM
Car: 1989 GTA
Engine: 369 TPI
No. I don't expect to do the actual installation until after the 1st of the year. I can mock them up on the block using the motor mounts and figure out my exhaust system including the exhaust termination boxes.
Old Oct 2, 2008 | 06:39 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
What I REALLY want to know is if I can use this K-member with my UMI arms...
Old Oct 2, 2008 | 06:48 PM
Car: 1989 GTA
Engine: 369 TPI
The RaceCraft K-member will accept the factory A-arms. If the UMI A-arms will fit the factory K-member then one would think it would work. Probably best to make a phone call.
Old Oct 2, 2008 | 07:13 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Hmm, are you sure it fits with factory a-arms? Cause I know UMI arms do fit with the oem k.
Old Oct 3, 2008 | 08:19 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Before you install your k-member, make sure you install your a-arms and check to see if they fit in the k-member.
Old Oct 3, 2008 | 08:20 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Originally Posted by 572_Rat
Before you install your k-member, make sure install your a-arms and check to see if they fit in the k-member.
572 really knows what he talks about.
Old Oct 3, 2008 | 08:32 PM
Car: 1989 GTA
Engine: 369 TPI
Thanks.
What I have done so far is to just slide the a-arms into the k-member checking on the room I will have for the exhaust. I did not slide the bolt through them. Everything seemed ok at that point. I will go ahead and do a pre-assembly.
Old Oct 4, 2008 | 12:40 PM
Car: 1989 GTA
Engine: 369 TPI
Today I went ahead and put the A-arms onto the K-member. The drivers side fit with no problems. On the passenger side I had to drop the A-arm down to the 90 degree point then the last bolt went right in.
Just wondering for assembly purposes if the best thing to do is lightly bolt up the K-member to the chassis and then put on the A-arms before the final tight down of the K-member chassis bolts. I was wondering if torquing down the K-member bolts first might have an effect on things such as tweaking the K-member ever so slightly.
Old Oct 4, 2008 | 12:47 PM
572_Rat's Avatar
The passenger side is where my problems were to, once the bolt is in can you freely move the a-arm up and down without binding. With mind, I could not even get the bolt through, but this was with the k-member in the car torqued down.
Old Oct 4, 2008 | 01:02 PM
Car: 1989 GTA
Engine: 369 TPI
The drivers side a-arm will almost free fall down. The passenger side won't but it does not take that much effort to move it. I don't think most people would give it a second thought during the installation.
But 572_Rat thanks for the heads up. I think we will install the arms before the final tightening of the K-member bolts.
Old Oct 5, 2008 | 07:09 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Good infos. 1989GTA, could you try bolting a stock a-arm to it and see if it does fit? I would really love to know. Oh and what size are the bushings on the tubular a-arms?
Old Oct 5, 2008 | 07:31 PM
Car: 1989 GTA
Engine: 369 TPI
I don't have a stock a-arm to bolt on. At least not yet. I will look into the bushing dimensions and post some pictures.
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Thanks man
Old Oct 6, 2008 | 10:43 AM
UMI Performance's Avatar
Yes correct, ours will fit with no issues on the factory K-member.
Thanks!
Ryan
Old Oct 6, 2008 | 10:50 AM
Thanks!
Ryan
Old Oct 7, 2008 | 12:51 PM
Car: 1989 GTA
Engine: 369 TPI
Here are the bushing dimensions on the RaceCraft A-Arms
Outside to outside is 14 1/8". One bushing is 1.1925" wide.
The other bushing is 1.205" wide. The holes are .50".
Old Oct 7, 2008 | 06:34 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Thanks a lot 1989GTA. Now if Ryan could pop in and give us the measure specs hes using on his arms. I dont have mine close to me atm so cant go measure them.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
92projectcamaro
Sep 24, 2015 08:09 AM
Mdenz3
Sep 17, 2015 08:36 AM
