replacing steering box
Old Oct 7, 2008 | 06:43 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
I am going to replace the steering box in my 91 RS convertible because it has all kinds of play in it, and I'm not sure which box to get. I read in the stickies that the boxes differed based on the factory tire size, but the orielly aprts database doesn't mention that. They list two pumps, one "with soft ride suspension" one "without." It lists hte same two regaardless of whether you search for an RS or a Z28, 5.0/5.7. My car has 16" wheels ( I assume they are factory) but I don't know anything about soft ride suspensions.)
Lastly, If it's all the same I'd rather get a tighter, more responsive steering box. I really don't like the play in the steering. The links to the two boxes are below. thanks.
http://www.oreillyauto.com/EW3/Produ...&currentPage=1
Old Oct 7, 2008 | 08:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: replacing steering box
this subject has been trashed/thrashed/beaten up/many times . my thoughts , and only my thoughts are as follows . make sure all other parts of steering system are good/or new . make sure all other items of play are good . remove top of steering box , clean/flush/blow out all trash/gunk . don't mess with internals , just look and inspect . if all looks good , as it most likely will . replace lube ( your choice ) , replace cover . adjustment screw on cover , tighten 1/16 turn , set jam nut , check it out , tighten more or less as required . has worked for me in the past . there can be play in the column as well . good luck .
Old Oct 7, 2008 | 08:42 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Links don't work
Old Oct 7, 2008 | 09:39 PM
Engine: 350 TBI
Originally Posted by krisb410
Links don't work
Hmmm...htey work when I click on them. Here they are again:
I did all that first. Had the steering box professionally adjusted, replaced center link, wheel bearings, ball joints, had rest of suspension professionally inspected. the steering column is good. there is still so much play that it is almost unsafe to drive the car. The steering box is only $130 on orielly. Sounds worth it to me. Thanks for the reply.
Anybody know whether I should go for the box the box that says with or without soft ride suspension?
Last edited by 91 RS Drop Top; Oct 7, 2008 at 09:43 PM. Reason: Automerged Doublepost
Old Oct 8, 2008 | 07:49 PM
Engine: 350 TBI
With or without soft ride suspension? Anybody?
Old Oct 8, 2008 | 08:07 PM
krisb410's Avatar
Whichever one has the highest ratio.
BTW: links still don't work
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
marcusaw
Aug 10, 2015 08:13 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
