Quick question about steering box
Old Oct 9, 2008 | 07:54 PM
metalmike6's Avatar
I've been adjusting the allen screw on top for a bit now and it's been taking so long just because of all the prep work I have to do to jack the car up between testing it... I don't have a garage and my driveway might as well be 90 degrees... Do I have to jack it up so the wheels are off the ground per http://www.monte-list.nu/tech/boxmesh.shtml
Or can I just adjust it and go?
Old Oct 9, 2008 | 09:51 PM
ShakerScoops's Avatar
Re: Quick question about steering box
You don't need to jack it up. Loosen the locknut, adjust the screw till it stops, then back it out 90 degrees. Then drive! you should really only have to do it once. Just dont drive the screw hard into the gear. You will be good to go.
Old Oct 9, 2008 | 10:11 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I did mine on the ground. Helped the car some. Probably should have done it again to fine tune it.
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
