need help on lowering springs
Old Oct 14, 2008 | 10:25 PM
88_thirdgen's Avatar
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
ok so i have a 88 camaro v6 and i want to get lowering springs on it and i was thinking of getting eibach sportline lowering springs that give it a 1.6" front amd 1.3" back but my question was that what would happen if i put v8 lowering springs on my v6 will it even lower it ,too stiff or be the same as v6 lowering springs??
Old Oct 15, 2008 | 02:07 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: need help on lowering springs
Taking a guess, would think that with the V6 it
would sit slightly higher and be slightly stiffer
in the front with the 100 or so lbs less wieght
you have.
The rear would not make any difference
Later
Old Oct 15, 2008 | 03:24 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
you'll be fine, just be sure your shocks are in good shape, so you dont slam your bump stops all the time...
Old Oct 15, 2008 | 06:25 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
do you think it will drop it the 1.6" the front springs say
Old Oct 15, 2008 | 07:40 PM
Rok_Stars_Bars's Avatar
Car: 1987 Camaro
Engine: Oldsmobile 455
Transmission: Th-700r-4
I have the same springs on my 87 camaro. I think it isn't lower enough. I was really disappoint. But I won them on cardomain so I can't complain.
http://www.cardomain.com/ride/573113
Old Oct 15, 2008 | 08:05 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
It probably wont be the whole 1.6 but it will be close. That will be the best kit to get for lowering like you want, and still have a smooth ride. It is a progressive rate spring just like the Pro Kit.
Old Oct 15, 2008 | 08:08 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
wow thats not low at all that is as low as mine is right now and its stock... i might just cut them but i would much rather get eibachs.
i really dont want to have any wheel gap so i was thinking that the sportlines would be the best way to go or else just cut them
Last edited by 88_thirdgen; Oct 15, 2008 at 08:11 PM. Reason: Automerged Doublepost
Old Oct 16, 2008 | 01:32 PM
jaykar's Avatar
I've got the Eiback pro in the rear and dropped it about
an 1 1/2", no gap.
Running Morrison coilovers in the front so can't help there.
Can set it anywhere I want.
Have it tucked about 3/4" into fender.
Looks so much cleaner when no gap.
Remember dropping the rear your LCAs angle has to be
addressed as to brackets if any kind of power in mind or
handling for that matter.
HTH
Later
Old Oct 16, 2008 | 02:15 PM
Car: 1987 Camaro
Yeah it didn't lower it like I thought really if it didn't say eibach sportline on the spring I would probably think it was a fake LOL
Old Oct 16, 2008 | 09:30 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
[/quote]
i dont wanna sound stupid but LCA's is an abbreviation for what and what do you think i should do cut them or go with sportlines. as you can see "Rock_Stars_Bars" posted pictures of his camaro with sportlines and its as low as mine is right now. Then again he only has the chin ground effect.
maybe they are bootleg sportlines it is not low at all. there is a difference between the after but it is not that low
Last edited by 88_thirdgen; Oct 16, 2008 at 09:35 PM. Reason: Automerged Doublepost
Old Oct 16, 2008 | 10:27 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
This is as low as i would want my f-body to be
Old Oct 17, 2008 | 01:13 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Your stock old springs usually are sagged with age so u don't really get the full drop the new lowering springs say. You can always trim your new ones to get the height u want, just go a little at a time cause when they're cut that's it. Later.
Old Oct 17, 2008 | 01:50 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
88_thirdgen
LCA stands for lower control arm. Its the two U shaped arms that go from th eaxle to a mount moint on the chassis in front of the axle. you need brackets that relocate the mount point on the rear end to keep the arm in parralel with the road. when you lower the car they will not be parralel anymore and can/will cause negative handleing and traction issues.
you can get them from several of the board sponsors for aroun $80-100
might want to upgrade to tubular lca's at the same time.
Old Oct 17, 2008 | 02:30 PM
jaykar's Avatar
LCA Brackets installed.
With the 1 1/2 rear drop lower hole brought it back to
horizontal, slightly higher front mounting.
Also when lowering any car, always check your shock
travel as to compression,worst case senario, hitting speed bump at speed, full of fuel and buddies in the car.
Also may need to trim bump stops.
When playing with suspension alterations, one change affects
other components.
HTH
Later
Old Oct 17, 2008 | 06:36 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
wow ur suspesion is built wish i had mine like that but i just want my car for a good looking daily driver untill i get my 02 ss 6 speed. will i need to adjust the lca's if i just put the out the box sportlines
Old Oct 18, 2008 | 03:52 PM
jaykar's Avatar
For a daily driver and if money tight, would'nt worry
about it.
All depends on plans for the car.
If planning on another car, save the money and put it
in that one.
Later
Old Oct 19, 2008 | 01:57 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
what drop kit is that the sportlines? or prokit?
Old Oct 19, 2008 | 10:43 PM
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
i have no clue what they are just found the pics ,but what i do know is that it is a 2" drop
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
