ZR1 wheels Offset
Old Oct 21, 2008 | 12:13 AM
epsmotorsports's Avatar
ZR1 wheels Offset
I have the 4th gen rear and was wanting to get 17 x 9.5 zr1 wheels.
Is there a big difference in using the 38 mm offset compared to the 56mm.
Anyone using the 56 mm got some pros or cons and anyone using the 38 or 36.5 mm got anything?
Old Oct 21, 2008 | 04:24 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: ZR1 wheels Offset
Whoops, NM, didn't see the part about you having a 4th gen rear.
FWIW: I have 17x9.5 +56mm ZR1s on my 4th gen rear. I would think you would need a 18mm spacer, thats about 0.07" for 38mm BS, or a 3/4" spacer for the 36.5mm BS.
Old Oct 21, 2008 | 09:23 PM
i dont want to use adapters on the front for racing purposes so whats the max size wheel and tire for the front? without spacers.
Could i use the billet adapters while racing?
Old Oct 21, 2008 | 11:09 PM
krisb410's Avatar
Unless you get the special ZR1s made for 3rd gens, you will have to run a spacer up front. I run a 2 1/4" spacer up front in order to clear the tie rods.
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
