Wheelie bars?
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Wheelie bars?
i think its time for some wheelie bars. i saw that spohn sells a kit. is anyone using it. also does anyone have pics of there wheelie bar setup?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Wheelie bars?
Try starting by using some front end limiters. I can see your front wheels fully extended so I know you don't have or use limiters.
Drop your instant center down and move it back if you can to reduce the amount of lift on the front.
Although I can lift my front wheels, I don't pull them enough to need wheelie bars and my car has enough power to run low to mid 9's.
Car: 1987 IROC
Re: Wheelie bars?
do you have limiters? if yes do you have any photos of the install?
Car: 87 IROC L98
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
Re: Wheelie bars?
wow, serprised i havent sceen you up at the track, and also you have a SERIOUS treck from new bedford to epping NH.... jeepers!
nice car by the way
nice car by the way
Car: 1987 IROC
darwinprice
17
Oct 11, 2015 11:51 PM
