Competition Engineering SFCs
Old Oct 29, 2008 | 08:55 AM
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Has anyone used the Competition Engineering bolt-in subframe connectors P/N C3120? Can they be welded at a later date? Has anyone delt with a company called Pace Performance? They are an EBAY seller and they have the C E sfc for $50 cheaper than Summit. I am specifically looking for a bolt in sfc that can be welded later on. Thankyou in advance
Old Oct 29, 2008 | 09:58 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Competition Engineering SFCs
If it can be bolted in, it can be welded in at a later date, just don't wait to long.
Old Oct 29, 2008 | 12:25 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Note at CE site - installation may require some floor pan modifications
There are some CE SFC's that you have to cut a channel in the floor pan. Check on that B4 you buy.
Old Oct 29, 2008 | 01:03 PM
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
I called CE and the floorpan mods they are referring to are the holes you need to drill to bolt the bars in. They make 2 different sets. The ones you refer to that require channeling the floor C3111, and the ones I am looking into C3120, which are designed to retain the factory style exhaust. I printed out the instructions which are very general. I was wondering if anyone had ANY PERSONAL EXPERIENCE with these with good pics. My search of the forum provided a couple of members with a few partial pics.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
