Spring questions...
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Spring questions...
I am redoing the horribly soft suspension on my 86 sport coupe... and i wonder why v6 springs are more expensive than v8 springs... but thats not the point... I found springs from napa, they have a 421lbs spring rates... but i found it while searching for v6 models...
http://www.napaonline.com/masterpage...Spring+-+Front
will these springs make my car sit higher in the front? I dont know for sure, but the free height is 14.63, opposed to the 15 something on the v8 springs, i just wanna know if i could use these without my car looking like its accelerating all the time... i am gonna use Koni GR-2 shocks and struts, they affordable...
and i also got some sway bars from a 94 Z28 with an LT1, i belive these will help handling...
Thanks for the help...
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Spring questions...
Koni GR-2? I think you mean KYB GR-2.
Those swaybars you got won't fit your 86 SC. I believe the 4th gens use a slightly different shape for their swaybars... so... they wont help the handling at all.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
V8's have various rates. Spring rates can be found in the following link:
https://www.thirdgen.org/forums/susp...a-springs.html
JamesC
JamesC
Car: 1989 Camaro RS
Engine: 2.8l v6
yeah kyb... my mistake... yeah im doing the suspension all around... because i think the springs are still the factory ones... and the shocks... well lets just say my car floats... how much would poly bushings help handling? because im thinking about getting the whole set... thanks for the info by the way...
JamesC
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
JamesC, know anybody who tried the Vogtland springs from Hotpart? Didn't mean to hijack, I'll start a new thread!
Car: 1989 Camaro RS
Engine: 2.8l v6
that is the current plan. i already ordered the shocks and struts... next check will be springs... front and rear... i figured while i was down the replace the bushings... a master kit cost around 140 bucks... and it will improve the handling a bit...
JamesC
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I agree with James about the master kit. Just go through the car and see what needs to be replaced. I would reccomend getting some high quality ball joints and tie rod ends while you are at it. Polyurathane will stiffen the car. Poly in the sway bars will affect the feel of the car a good deal.
A word of caution about polyurathane in the rear lower control arms-
In the LCAs, the polyurathane can create bind in hard cornering. This bind is caused by the LCAs not being able to work as they are designed to. As the rear suspension is designed, the rear of the car moves over the rear axle (imagine the axle as fixed and the body as mobile). When the car enters the turn, the body tries to move to the outside of the turn due to momentum, while the axle tries to remain in place (you hope). Now, if taken from a helicopter view, this motion must have some affects on the suspension linkages. The most appearent is in the LCAs. As the body moves over the axle, the LCAs are put into stress. The factory bushings allowed for this by flexxing and allowing the energy of the movement to absorbed and dissapated easily. Polyurathane is stiffer than the rubber, and doesn't allow this disapation so nicely. They can cause the bind I mentioned and snap back into their original postion. I've had this happen to me on several occasions, and it's interesting to say the least.
Car: 1989 Camaro RS
Engine: 2.8l v6
yeah i heard about that... so greaseable sway bar bushings... good call joints and the rod ends... i an pretty sure i will be happy with it... thanks for the help...
Car: 1989 Camaro RS
Engine: 2.8l v6
i just got a big speeding ticket... i already ordered the shocks and struts, here is my question my springs are incredibly worn, how would new shocks work with old springs?
Car: 1984 Camaro
Engine: 327
Transmission: TH700-R4
Axle/Gears: 7.5" 3.23 Posi
Shop Wisely (Re: Spring questions...)
I am redoing the horribly soft suspension on my 86 sport coupe... and i wonder why v6 springs are more expensive than v8 springs... but thats not the point... I found springs from napa, they have a 421lbs spring rates... but i found it while searching for v6 models...<snip>
If you can determine the Moog part number for the springs you want, go comparison shopping here:
www.frugalmechanic.com
You might be able to save a few bucks and use them to help pay for your speeding ticket. I just ordered a pair of Moog 5660's (598 lb. spring rate) for $54.21 with free shipping. Summit sells the same springs for $64.39 plus S&H.
My research reveals that GM has used the same configuration for front coil springs with various spring rates on a wide range of vehicles for several decades. What may be considered as heavy duty or high performance springs for an F-body may be stock replacements for a full size wagon or pickup truck.
Cheers!
LT1Formula
Oct 8, 2015 08:34 PM
