Center Link Replacement Problem
Old Nov 18, 2008 | 08:20 PM
adamlinn13's Avatar
I am replacing the centerlink in my 1984 Chevy Camaro v8 5.0L H-VIN, and I'm having a problem getting the tie-rods reattached to the centerlink and the nuts aren't going on all the way. The nuts start getting tight on the tie-rod bolts and then the tie-rod bolts start turning.
Is there an easier way to get the nuts back onto the tie-rod bolts?
Old Nov 18, 2008 | 08:29 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: Center Link Replacement Problem
Get a pry bar of some type and apply firm upward pressure on the bottom of the tie rod while tightening the nut. This will help seat the taper and allow you to torque on the nut.
Old Nov 23, 2008 | 02:00 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
You can also squeeze the bolt in with a pair of channel locks or a clamp while you tighten the nut. Anything to seat it in so the taper can grab.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fronzizzle
Aug 9, 2015 01:15 PM
