Suspension Choice
Old Nov 18, 2008 | 07:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Suspension Choice
Which should I salvage from or go an buy for my 89 camaro rs?
I'm looking for something to buy for my car in the "long run".
I was looking into buying a 383 or 454 engine to swap into my car; i just heard that if i had to much power pushing my suspension would twist or something.. so i'd like to just get that done.
regards,
Timinsk
Old Nov 18, 2008 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Suspension Choice
Our cars are unibodies which means they flex. SFC's, Wonderbars, and STB's will help with that.
JamesC
Old Nov 18, 2008 | 09:23 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Welding all the seems for the subframes and in the engine bay and what not will also help a ton... but it is very labor intensive.
Old Nov 18, 2008 | 09:33 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
What should be welded then? Like are you talking about some of the peices of "bolted" down metal there is that should just be welded instead?
Any links to buy things to help this as well? just curious
Old Nov 19, 2008 | 04:09 PM
Car: 1987 IROC-Z
Transmission: TH350
These are the most popular choices when it comes to going aftermarket with suspension.
UMI
Spohn
Hotpart
Old Nov 20, 2008 | 10:54 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Make sure that if you are doing any welding on the car that it is setting on as flat and level a surface as you can find. You don't want to weld the car when the suspension is loaded unevenly.
gixxer92
May 18, 2017 11:20 AM
LT1Formula
Oct 8, 2015 08:34 PM
