Original ride height?
Old Nov 15, 2008 | 05:33 PM
cjltn1's Avatar
Car: 1987 Pontiac Firebird
Engine: 305 Rochester Carb
Transmission: 700 R4
I am trying to find the original height (off the ground) of my 1987 Firebird. It seems to be a lot lower than the others I've seen? & bottoms out on everything. Can anyone help out please?
Old Nov 17, 2008 | 07:47 AM
miRob's Avatar
Re: Original ride height?
http://en.wikipedia.org/wiki/Third-g...ntiac_Firebird
It says the height is 49.7"'s
Old Nov 17, 2008 | 07:52 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
How many miles on car? Maybe time for new springs.
Old Nov 18, 2008 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I 'believe' that ride height is 27 1/2".
JamesC
Old Nov 20, 2008 | 03:58 PM
cjltn1's Avatar
https://www.thirdgen.org/forums/imag...ies/iagree.gif Thanks for all the replies! My first ever POST....You're probably right BADMAN , i even tried a cheapo way out by buying a pack of those twist in spring helpers for about 10 bucks at Autozone, but, each spring twist was spaced to far apart for them to work as a temp fix. They just went completely between the twists? I was actually able to change the shocks and struts myself in the garage, but, im a little afraid of the springs, would'nt the rear end become "dog tracked" if it wasn't reinstalled perfectly? Don't know, just scares me a little... FYI.. I know you guys will say REDN**K, it was my graduation gift in 1987. I haven't had the heart to sell it, i just love it. Maybe it will last till my 4 yr old son is 16, if he can afford to drive it? Not many miles, it just stays covered in the garage.
Old Nov 20, 2008 | 04:26 PM
JamesC's Avatar
The rear springs aren't indexed. You could have easily swapped them out when you did the shocks. The front springs ARE indexed and can, if indexed improperly, cause issues. A search would provide more info on swapping the fronts. While not terribly difficult, there is modicum of danger involved. (I was eyeing a spring compressor at a swapmeet and an older gentleman asked me how my dental plan was.)
JamesC
Old Nov 20, 2008 | 05:54 PM
cjltn1's Avatar
JamesC
Most Excellent, Im a IT (information Tech) man, so i myself was wondering if my teeth were an issue, or HEAD??? So, just do as i did before, and replace one spring at a time?, because that's what i did with the Shocks, right?, You Guys know EVERYTHING, You're just Great, just freakin awesome' !!!!!!!!!!!!! I might be dumb about some of the mechanical things but not stupid!!!!!I still want to count the teeth in my head and race on PINKS ALL OUT one day! Thank You MY THIRD GENERATION PONTIAC WILL RUN FOREVER, THANKS TO YOU GUYS
Old Nov 20, 2008 | 06:30 PM
JamesC's Avatar
Yep.
JamesC
Old Nov 20, 2008 | 06:49 PM
cjltn1's Avatar
Yep.
JamesC
Again, Thanks, i'll let you know how it worked. Cristopher from N.C.
customblackbird
Aug 15, 2021 10:16 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
