What rims are these?
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Any idea what they are worth with good tires and zero curb rash? The center cap says "Spirit of America."
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: What rims are these?
They could be American Racing Outlaw I, or even Ceterline Autodrag 3.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Center caps don't mean much. It's easy to put in a custom center cap. They look like American Racing Outlaw I rims.
http://asp.americanracing.com/wheels...heel§ion=C
They're a cast (street rim) copy of the spun aluminum (racing) Centerline Autodrag rims. I have a set on my truck but not on the car.
Worth? Depends on the size. Jegs lists the 15 x 8's for $92 each
http://www.jegs.com/p/American+Racing/832551/10002/-1
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
They don't use the conical lug nuts, not sure if that helps. They use the pain in the *** lug nuts that you have to center the stud in the hole yourself with your foot+both hands before you can slip the nut on.
Car: 87 IROC L98
I have a pair of Autodrags for my truck and those use conical wheel nuts.
My Weld Draglite and Prostar rims on the car are designed for shank nuts and washers.
Real Center Line Aurodrag rims will say Center Line on them.
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Also Centerlines use real rivets, I believe those are American racing, used to sell them years ago
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
