rear coil spring insulator / isolator
Old Dec 2, 2008 | 10:14 AM
mark87Z28's Avatar
The track bar brace bolt near the rear right spring had been installed backwards and was rubbing against the spring. The rubber isolator on top of the shock is shot and now the spring can spring it makes a clunking sound. I need to replace the isolator and would like to use ES but they do not have a "listing". Does anyone have the correct ES part number? The OEM ones are $24.00/each.
Old Dec 2, 2008 | 10:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear coil spring insulator / isolator
IIRC, they're fourthgen replacements and will jack the rear of the car up. Dime a dozen at a yard.
JamesC
Old Dec 2, 2008 | 10:32 AM
mark87Z28's Avatar
The dealer is offering 4th gens to install on a 3rd gen? It gets more challenging all the time. We've been picking over the boneyard really good lately. The problem is the cars are in sand and we can't jack up the rear to get at the shocks. Another obstacle to overcome.
Old Dec 2, 2008 | 12:13 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I see them on Ebay every once in a while.
Old Dec 2, 2008 | 07:53 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I have some. . . by the way the 4thgen ones are the same as the 3rgen ones in all the lt1 cars iv owned or parted out. . . maybe the 98 - 02 cars are different
Old Dec 2, 2008 | 08:36 PM
krisb410's Avatar
The ones sold now at dealers or other GM parts sources, are the taller designed ones. They'll lift the rear an inch or so.
Old Dec 2, 2008 | 11:06 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I got some new ones from GM when I swapped my stock springs for my Pro-kit and the back of the car went up by 3/4"-1"... can't remember exactly.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 25, 2015 07:34 PM
db057
Aug 22, 2015 08:17 PM
TA8487
Aug 11, 2015 09:02 PM
