my tie rod end went splat
Old Dec 6, 2008 | 10:00 PM
chattersonm's Avatar
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
i was driving the other day and then right when i turned my wheel to park i heard a loud dragging noise...
i guess my tie rod eaither broke or was disconnected...
does anyone know how much it cost to get it replaced (aka labor)
cause i really need a vehicle right now
Old Dec 6, 2008 | 11:24 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: my tie rod end went splat
Not the worst thing to replace! I did my first tie rod ends on my 86 olds cutty last winter. Shop would prob. charge 1 hour and part... under 50??? not to sure. Chances are that if your front end is falling on the road other components need attention as well.
Old Dec 6, 2008 | 11:39 PM
Stephen's Avatar
Car: 87 GTA
You GUESS? You haven't LOOKED? Not exactly a hard thing to see.
Did all four (2 inners, 2 outters) over a year ago & just MADE SURE they equaled the old lengths. Never got my car realigned & have NO alignment/steering issues either.
Old Dec 7, 2008 | 08:28 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
It's easier than changing the ball joints.. With parts and labour.. $120?
Old Dec 7, 2008 | 08:34 AM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
^^But a shop is probably going to charge for an alignment too, maybe another $70...
Old Dec 7, 2008 | 12:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you didnt wreck the car immediately after hearing the noise, and still got it home, i would really doubt it was the tie rod. Its the only thing that holds the wheel in line with the other. If one broke, that wheel would have no control and would wobble and turn wherever it wanted to.
I would suggest getting down and looking under the car and see exactly what broke before you start assuming things.
-Phil
Old Dec 7, 2008 | 11:39 PM
Engine: 2.8 v6 MPFI
Transmission: LB8
-Phil
sorry, i tend to have a sarcastic voice when i type on the internet.
it is my tie rod end because when i looked under there, it was just sitting on the ground and i pushed my tire with ease. so, judging by what everyone is saying, i am guessing it wont cost me an arm and a leg.
thanks everyone, i wish i was equipped with the tools and space to do it my self, but it seems i will just have to take her to the shop to get fixed up.
Old Dec 7, 2008 | 11:47 PM
Stephen's Avatar
Car: 87 GTA
Takes no tools to look though. Except a jack, if you wanna lok even harder.
Best to look FIRST, so you are prepared for the BS a shop gives you, trying to claim that EVERYTHING is broke and HAS to be replaced NOW.
Old Dec 8, 2008 | 12:07 AM
Engine: 2.8 v6 MPFI
Transmission: LB8
i'm gonna get out there and take a look at it tomorrow, it is so danged cold lol, and i dont have to work tomorrow, so its cool
Old Dec 8, 2008 | 06:29 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
If your looking to take on simple do it your self projects this might be a good one to start with. Im not sure where your car sit now but it can be fixed any where. make sure you jack it safely... measure your iner tie rod to your outer tie rod to aviod alignment issues. And buy your self a manual. It will pay for itself the first couple uses.
Or you might have to get a tow truck $70... shop$80... part...$50. not a horible idea. But you will not learn anything.
Just something to consider. Good luck
Ghettobird52
Apr 21, 2020 08:44 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
gixxer92
Sep 1, 2015 04:32 PM
zayne0
Aug 24, 2015 07:22 PM
