Torque arm removal question!
Old Dec 7, 2008 | 07:37 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Hey guys,
Need to replace my clutch, just had a questions about the removal of my torque arm.
Now my haynes manual says I have to remove the coils in the rear end to prevent "rear axle forward twist." Is this necessary? I was talking to a guy who figured I should just leave em on. This would make it alot easier.
And regarding jack points...I know where to place a hydraulic jack to lift either the front or rear, but I really have no clue where to place the jack stands. I realize they are susposed to go on the rear axle if raising the rear, however, my car has a swaybar that prevents this. In addition, if I needed to remove the coils, I'd need to find a new place for the stands regardless, so I could drop the rear end.
Right now my car is just sitting on ramps/cinder blocks.
Where are the ideal points for the jack stands??
Thanks!
Old Dec 7, 2008 | 07:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Torque arm removal question!
for the rear, you can put the jack stands just ahead of where the lower control arms mount to the body, or on the "frame" part just inboard of that part.
removing the springs will probably make things a lot easier.
Old Dec 8, 2008 | 01:40 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Thanks for the help!
I figured one of those frame sections was the right area, but when I knocked on it, it didn't sound very strong. Also, doesn't it have a bit of an angle to it (sloping backwards??).
What about the front?
Old Dec 8, 2008 | 01:51 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
I have used those areas on the rear before.On the front I put my stands under the A-arms where the spring buckets stick down.
Old Dec 8, 2008 | 02:16 PM
Stephen's Avatar
Car: 87 GTA
You don't HAVE to pull the rear springs. I never have, when doing a clutch.
The rear end will rotate, pinion up, and the torque arm will rest against the floor. Pull the tranny,do the clutch, them put it all back together. Pull the torque arm down, redo its mount. Done. No big deal.
Old Dec 18, 2008 | 08:43 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
yeah, there's not as much pressure on the torque arm as you might think. i was led to believe that the thing would punch a hole in the floor if you let it go with the car jacked up, in reality there might be 10-15 lbs of force at the trans end (at least on my car with old rear springs). to be safe though, lay a thick towel or t-shirt over the top. at least you'll protect your undercoating.
Eric B
Old Dec 18, 2008 | 08:49 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
dang! first double post in years! sorry!
E
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Aug 8, 2015 07:09 PM
