cant get the right springs!
1 Post
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
ok i just replaced my rear shocks and springs and my plan was to also replace front struts and springs so i got struts and that was fine but im now on my 3rd set of springs and every set is like 4 inchs longer then the stock springs yet they are the right part number for the listing in all the shops ive been toso maybe all the places have the wrong numbers? so my question is do anyone know how long the springs should be and does anyone have the right part numbers? the ones im returning tomorrow have the part number fcs5598s and they are roughly 15.5" long
Re: cant get the right springs!
Depending on what the spring was dezigned for it will be longer.
Not sure about all of them but front drag springs tend to be longer, and have a smaller diameter wire.
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
From what I remember, my Moog fronts were a little higher than my worn out stock WS6 springs. I can't give you a length at the moment, but I'd go with Moog replacements; #5662 fronts, #5665 rears. Give it a month or so for the new springs to settle.
1 Post
ok thanks guys ill try today and just to be clear my problem wasent with the springs being a little bit it was the fact that they wouldnt even fit up under the car!
LT1Formula
10-08-2015 08:34 PM
