Best adjustment settings on Koni Red/Yellow?
Old Dec 22, 2008 | 12:10 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I've installed Koni Yellow struts on the front of my 88 IROC and Reds on the rear. The roads I drive are somewhat rough. What settings have you all found works the best? Nitro-Nicky
Old Dec 22, 2008 | 07:51 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Best adjustment settings on Koni Red/Yellow?
It depends alot on your car and what springs/sway bars you're running. Best thing is to go with full soft for just driving around and to follow the adjustment instructions on KONI's site to adjust them for yourself. I think it's start at full soft and adjust stiffer by half turns until you get the ammount of roll control you want or something of that nature. Most run rear Yellows at 0-1 in most situations, but you may want a stiffer setting on the Reds to match the front Yellows. Why'd you go with a mismatched set, if you don't mind my asking.
Old Dec 23, 2008 | 12:25 AM
neagan's Avatar
The Red's came with a box of stuff I bought from another member, so I figured that the should adjust up to be equal with the new front Yellers. However, they are much-much softer than the Yellows and that's what led to me asking about it. The back bottoms out like an old hooker. Nitro
Old Dec 23, 2008 | 03:34 AM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
how do old hookers bottom out exactly? lol if u dont mind me asking...
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
