Potential 2002 Firebird Trans-Am Buy- Need Advice
Hey Everyone,
I've discovered 2002 Firebird Transam for sale locally. It has 70k on the motor and tranny, 5.7 LSI engine and ram air hood. The guy says that "The car is driveable, it just shakes when you apply the brake hard and waers tires really fast." This is because of a bent frame that is out of spec. So my question is depending upon how much the frame is bent, would it be possible to get the frame straightened and turn the car into a daily driver, if so how much would this cost?
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: Potential 2002 Firebird Trans-Am Buy- Need Advice
I'd pass. There are too many really nice LS1 F-bodys for sale relatively cheap that I would buy one with serious issues.
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Id pass. A frame can be 'fixed' but it will never be back to 100% which means alot when it comes down to the safety of you and others. You can find another one that is in better shape for a little more money.
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
If the price is good, buy it and part it out. Im sure you could make money out of this.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
part it then just buy a nice IROC! Better looking too and thirdgen related
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
if its cheap, don't part it. buy it and put some parts on your third gen! this screams LS1 swap!
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
How much for the car? I'd considering buying it for a LS1 conversion. There are an absolute wealth of parts that'll swap onto a 3rd gen- brakes, engine/trans, interior, wheels, rear end, etc.
Are you sure the issue isn't just warped rotors and a bad allignment and not the frame?
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
