power steering pump or box?
Old Jan 11, 2009 | 08:50 AM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
somewhere in my steering system something is gone. when i turn full lock the engine drops like 700-ish rpms and the pump screams. and the steering feels chunky like a volume **** or something just not smooth lol. plus when i got the car the power steering pump was bone dry. and the hoses are leaking. so my questions are should i replace the pump or steering box? and will any of these parts come with new hoses?
Old Jan 11, 2009 | 09:59 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: power steering pump or box?
I'd guess the pump is toast. A new one will not come with hoses, but they're probably around $20-$30 for each hose. The return hose may just be a standard rubber almost fuel line that should be $1.10/foot. I just put a pump on a van, and the directions say to pre-bleed the system before operation. My guess is this means the pump really doesn't like being dry, along with squealing is never good.
Old Jan 11, 2009 | 10:32 AM
Brennan's Avatar
yeah i have no idea how long the pump was dry. i bought the car about 5 hours away from where i live and drove it home like that
Old Jan 11, 2009 | 10:39 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd recommend both. Although you may get by with just changing the pump, there's always a risk that metal from the failed pump got into the steering box. Over time, it will cause the steering box to fail if it hasn't already.
Old Jan 11, 2009 | 10:44 AM
Brennan's Avatar
is there a way to flush the box or something? im kinda workin on a loose budget and im assuming that the box aint cheap
Old Jan 11, 2009 | 07:34 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Some drag racers just take the pump and lines off. As long as you have the v-belts instead of a serpentine setup, and want a workout, you could probably do that to not have to buy anything.
Old Jan 12, 2009 | 03:57 PM
Brennan's Avatar
well this car was a daily driver but now its more of a weekend warrior but i still want it to be drivable lol and theres no drag strip anywhere near where i live
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
