Torque specs for tie rod/ball joints etc. HELP!
Old Jan 11, 2009 | 07:01 PM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
I am in the process of installing alll new front end parts on my 1986 Iroc Z. I need to know what the torque settings are so i can put everything back togather before i take it to an alignment shop. EVERY part in the sterring system is new . Thanks for your help.
Old Jan 11, 2009 | 08:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Torque specs for tie rod/ball joints etc. HELP!
Install very tight to align the cotter pin hole. If hole doesn't line up, tighten a bit more.
Old Jan 11, 2009 | 08:55 PM
Car: 1986 Iroc z
Engine: 350 tpi
ok thank you. but according to the haynes manual i need to torque them. i just dont want to damage them by tightening too tight. Of course im not gonna put brute force on them but i just want to make sure im doing this right the first time. I appreciate your time. any more feed back is welcome.
Old Jan 12, 2009 | 03:52 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
i wrench for a living and its like he said tight works
if you cant get the cotter pin in make it tighter
if it makes you feel more comfortable i usually tighten them down with an impact but do as you feel
zig
Old Jan 12, 2009 | 07:43 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I use the box end of a wrench and usually snipe it with another wrench to pull it tight. I'll use an impact if I have room but not very often on automotive parts. Changing a tie rod on a truck I need a 15/16" socket and sometimes need a 3/4" impact to get the old ones off.
If you have a repair manual, there should be a torque spec in it but I've never torqued ball joints, tie rod ends or anything else like that. They're all a tapered pin fit so it can only be tightened so far.
Old Jan 12, 2009 | 07:59 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
If you do a search on here you will find the torque spec's. I have posted this at least 3 times
http://www.camarotech.com/suspension.html
Old Jan 13, 2009 | 05:39 AM
Car: 1986 Iroc z
Engine: 350 tpi
ok thank you very much. I love this team of thirdgen guys/gals you are ALL a big help!!
zig
thanks Zig. your input is VERY helpful as well as everyone elses. You guys/gals RULE!!
Last edited by 1986iroc350; Jan 13, 2009 at 05:41 AM. Reason: Automerged Doublepost
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
ericjon262
Sep 11, 2015 06:07 PM
angel2794
Sep 8, 2015 06:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
SlowAZ28
Sep 2, 2015 05:19 AM
