Front A-arm help
Old Jan 15, 2009 | 02:08 AM
screeminchicken's Avatar
Front A-arm help
Thanks to all of ur tips , I got the K -memeber out and seperated ready for cleaning and painting. (for the LS1 swap)
Here are some pictures
Two things keping me from getting the A-arms ready . :?
1. the front ball joint - do I just hammer it out? I tried to use the pickle fork with no luck
2. The Control arm bushing - any tricks on getting those out. I would like to replace them with PST or polyurethene ?
Old Jan 15, 2009 | 08:07 AM
BMR Sales's Avatar
Former Sponsor
Re: Front A-arm help
You will need a ball joint removal tool available at your local auto parts store for rent for around 160 to 180 dollars. As far as the bushings go just get them pressed out or burn the rubber out and hammer away at the outer shell that's in the control arm.
Old Jan 15, 2009 | 05:02 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
You can probably pop the balljoints out with a heavy hammer by hitting on the castle nut. Go to the local parts store and they will loan you a balljoint press to put the new ones in.
You might want to weld in a strap across where you have the yellow circles, this will help keep the control arm from distorting when you press out or press in the new bushings. As noted fire can be your friend.
Old Jan 15, 2009 | 05:26 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
local parts store machine shop charged me $20 to press out 4 bushings and 2 ball joints and install new ones. $20 well spent those bushings are a Bitch to press out.
Old Jan 15, 2009 | 07:41 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Yeah, if you're replacing those ball joints, just beat the crap out of them to get them out. Just don't damage/warp the arm. Probably best to press the bushings out/in. Much harder to DIY. Make sure they don't warp the arm in the process though.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
