Manual steering box
Old Jan 27, 2009 | 10:01 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Manual steering box
From transam84: 'I mocked up the man gearbox I just bought on friday at the junkyard and there are 2 little mods you have to do to make it work. if your standing at your drivers side fender and looking down at the gear box you will have 2 mounting hole on top of the gearbox, the one closer to the firewall needs a slight mod. you will need to pull out the ole angle grinder and grind a slot in the webbing to accomidate the bracket that the swaybar is bolted to, bad description of the brkt but you will know what I meen after you get your old gearbox out. one other very little mod was I had to use a hammer (I know this sounds bad) and dent the frame just slightly enough to make the gear box sit flat to the frame.'
Has anyone else had these problems? If so, was it with the S-10 steering box?
Old Jan 30, 2009 | 01:21 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: Manual steering box
ttt
Old Jan 30, 2009 | 08:31 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
yep, same thing I had to do.
Old Jan 30, 2009 | 03:51 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I didn't do anything like that, but I also took my front sway bar off well before I did the steering box. The box is one from an s-10.
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
