Rear ladder bars
Old Jan 30, 2009 | 09:40 PM
metaylor's Avatar
Car: 1988 SAAB 900
Engine: Fuel Injected 4-Cylinder
Transmission: 5-Speed
Axle/Gears: No Idea
Rear ladder bars
I am thinking about redoing the rear suspension on my 89 RS and I was cruising around on summit looking at rear traction bars and sway bar kits and the like when I found this:
http://store.summitracing.com/partde...061+4294848962+
Now, can somebody look at this and tell me if it includes everything that I need, or what else would I need to put it on mine. oh yeah, and is it worth the money?
Thanks!
Old Jan 30, 2009 | 09:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rear ladder bars
Looks like a torque arm, not a ladder bar.
Old Jan 30, 2009 | 11:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's a BMR universal torque arm for third gens. It replaces the factory stamped steel torque arm. The BMR torque arm is shorter than a typical torque arm. It's universal as in they use a separate crossmember to mount the torque arm regardless of what transmission is in the car. Other designs such as Spohn, move the front mount into a transmission specific crossmember.
Old Jan 31, 2009 | 10:02 AM
metaylor's Avatar
Car: 1988 SAAB 900
Axle/Gears: No Idea
Thanks, that explains a lot, so, is there anywhere I could get a ladder bar kit?
Old Jan 31, 2009 | 10:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
There is no third gen specific ladder bar kit. When I had ladder bars in my car, they were a universal kit. To make them work, I had to section the rear floor so that the ladder bars could pass through the floor.
Why do you want to change from the torque arm suspension to a ladder bar suspension?
Old Jan 31, 2009 | 11:16 PM
metaylor's Avatar
Car: 1988 SAAB 900
Axle/Gears: No Idea
Honestly, I don't have a clue, I guess it's just because all you ever hear about is ladder bars and four-link suspensions. part of it is because I really don't know what I want to do, this is my first project car and only the third car I've really worked on, so when I look at what I can do I just start looking at all the possibilities and sometimes I get lost. (I can weld and the like though so I think I'm gonna be ok.)
Old Aug 30, 2009 | 01:36 PM
thecamarokidd's Avatar
Car: 1983 camaro z28,1970 gto
Engine: 355 sbc rollor motor
Axle/Gears: bull @#$% stock
i also want to go from the stock set up to a 4 link or a ladderbar suspension if anyone knows the best way to do this let me know. i want to do that and put in a ford 9inch rear
Old Aug 30, 2009 | 04:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the torqe arm setup works very well, for drag and handling. No real need to do a 4link or ladderbars unless you only wat to go drag racing and want to run massive tires.
For torque arm, check out BMR, UMI, and Spohn. Global west also makes one, its a lot different that the previous, and apparently works very well for handleing applications.
If that is the way you want to go, a 4 link would be best, but requires backhalfing the car, which is very expensive and labor intensive.
Old Aug 31, 2009 | 11:28 AM
Shagwell's Avatar
Car: projects.......
Personally, I wouldn't go to a 9" unless you really, really need it. A good 12-bolt will handle quite a bit, and a Dana 60 will handle just as much, both w/o robbing as much power to pull.
Unless you are planning to "back-half" the car and run large slicks, you're far better off to stick with the stock suspension. There's guys running in the 6's in the 1/4 with stock suspension and drag radials.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
z28addict8490
Aug 7, 2015 08:48 PM
