motion ratio
Old Feb 6, 2009 | 12:41 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
motion ratio
Anyone have the motion ratio numbers? I have some data I'm trying to verify.
Old Feb 7, 2009 | 08:09 PM
Guest
Guest
Posts: n/a
Re: motion ratio
Front coils set at aprox 42% of wheel motion by my calculations on my car. My scrub radius was slightly more positive than stock with my brake package mount surface being about .300'+ outward. A standard wheel centerline motion to spring pocket may be about 43-44%.
Dean
Old Feb 8, 2009 | 12:52 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: motion ratio
How'd I know that you'd be the only one who would (or could) answer this? haha
Old Feb 9, 2009 | 10:19 AM
Guest
Guest
Posts: n/a
Re: motion ratio
Thanks 5.7, but it is quite easy to figure. You take the distance from the imaginary points between the mount ears of the lower control arm - to the centerline of the tire contact patch. Then the same from the ears center to the spring pocket center. The spring pocket center is aprox 42% and its motion of travel is parallel with the balljoint so there is no angle of reduction to speak of.
Now with the strut, it has more of a larger motion ratio since its lower mount is the spindle, yet the upper mount will vary in angle based on camber and caster specs PLUS ride height of vehicle. TH elower the car is, the greater the angle and the reduction of compression AND rebound rates. if the strut were mounted straight up? the motion ratio would be 100%. Mine is lowered and set back quite an angle with caster so mine I would guestimate quickly to be about 92-95% motion ratio of the strut in proportion to how much the wheel travels. So in other words, if the wheel hits a bump and travels upward 2", the strut shaft only travels about 1 7/8" aprox.
Dean
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
