seeking input on improving turning
Old Feb 13, 2009 | 07:47 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Ok, so I have a pretty much stock '87 Z-28. My car has a quirk I'd like to fix. When I turn the wheel all the way in one direction, the car will turn smoothly for the first 3/4 of the wheel turn but eventually the tires start to skid? At least it feels and sounds like skidding. Why is it doing that? I use my car as a daily driver and when Im in parking lots, it can be a pain trying to turn into parking spots. I know these cars arent known for being tight turners, but anything would help.
Old Feb 14, 2009 | 02:00 AM
Guest
Guest
Posts: n/a
Re: seeking input on improving turning
That last portion of turn ratio to lock renders the ackerman angles to fail and cause a toe-in condition. This makes the tires fight eachother. Skinnier tires will help. It is an inherent defect built in to the stock geometry.
Old Feb 14, 2009 | 06:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you haven't installed a Wonderbar, you might wish to consider the following link:
https://www.thirdgen.org/forums/susp...questions.html
JamesC
italiano67
Dec 11, 2016 09:21 AM
deracer
Apr 11, 2016 12:04 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
