Front tire question
Old Mar 2, 2009 | 06:36 AM
heff17's Avatar
Car: 89 Camaro
Engine: 383 w/ 450HP
Transmission: TKO-600
Front tire question
Ok ive got rims that are 17*9.5 front and 18*10.5 rear. Ive never done the 2 different wheel sizes so im kinda confused on what size tires would look right on my camaro.
I know for the rear im going with 295/35-18 26" dia
but for the front should i use
255/40-17 25" dia or
255/45-17 26" dia
Thanks!
Old Mar 2, 2009 | 08:09 AM
Stephen's Avatar
Car: 87 GTA
Re: Front tire question
Neither....
255 on a 9.5" rim? Too narrow. I have 275s on my 9", which are the correct sized tire for the rim.
255 is too narrow for a 9.5" wide rim.
Old Mar 2, 2009 | 09:30 AM
heff17's Avatar
Car: 89 Camaro
ok so a 275/40-17 its a 25" dia. Will that combination of tires look "right" on my car?
Old Mar 2, 2009 | 09:33 AM
BMR Sales's Avatar
Former Sponsor
255/45-17 26" dia
Thanks!
You could run either tire. The 255 is going to fit fine on a 9.5 inch wheel. I would personally run the 25" in the front if you have the 26" out back.
Old Mar 2, 2009 | 09:44 AM
heff17's Avatar
Car: 89 Camaro
Anybody have any pics of a setup like this? 18's in back and 17's up front with tire sizes? Id just like to see what they look like before i drop 600-800 on a set of tires.
Old Mar 2, 2009 | 09:48 AM
BMR Sales's Avatar
Former Sponsor
I dont have any pictures of 3rd gens with that specific wheel and tire combo but can assure you the 255 and 9.5 will fit fine.
Old Mar 2, 2009 | 10:06 AM
Stephen's Avatar
Car: 87 GTA
BMR Sales is SO wrong.....
That is the MAXIMUM width wheel, for a 255. So it's gonna be STRETCHED to fit. A 255 tread is 8.5", so it is narrower than the 9.5" rim. So its gonna look STUPID.
Look on Tirerack.com.....Research the tire manufacturer specs, to see what tire fits what width wheel.
Old Mar 2, 2009 | 10:24 AM
heff17's Avatar
Car: 89 Camaro
i did look on tirerack first and they gave the wheel width for the 255/40ZR17 at 8.5-10"
Would i be better off just going with a 275?
Old Mar 2, 2009 | 10:34 AM
Stephen's Avatar
Car: 87 GTA
Tire to wheel width specs depends on WHICH tire manufacturer you go with. Some tires run wider than others, some run narrower.
I've had 255s up front, on different wheels. I'm now running 275s up front & love the increased front end grip in the corners. No more "front end plow" in hard cornering.
Do you want to go fast in a straight line? (go wide) Or go fast in corners? (go narrow)
Old Mar 2, 2009 | 11:50 AM
BMR Sales's Avatar
Former Sponsor
I am? Please explain....
You put "stretched" in all caps like its a big deal, a 255 on a 9.5" is almost no stretch at all. Now if you were putting a 225 or smaller on the wheel then yeah I would say that is a pretty good stretch.
Old Mar 2, 2009 | 12:41 PM
Stephen's Avatar
Car: 87 GTA
Simple....Looks the TIRE MANUFACTURER specs....It is towards the upper range...Meaning it will have the sidewalls stretched out to reach. Not exactly ideal. Some of the tire manufacturer don't even say their 255 will fit that wide of a wheel.
If a 275 is "normal" on a 9" wheel....)and by "normal", I mean like 4th gens....275 on a 9" wheel, among other cars I'm sure), then going to a narrower tire on a wider wheel doesn't make any sense.
I have 275s on my 9" wheels. Perfect fit.
Again I ask.....Narrower tires on a wider wheel? Good for the 100-spoke, lowrider crowd, I guess.
Old Mar 2, 2009 | 01:13 PM
BMR Sales's Avatar
Former Sponsor
Not exactly ideal.
Says who? You? The OP went to tirerack.com like you suggested and even there it said a 255 is good on an 8.5 to 10 inch wheel. Im not here to argue, just point out the fact that you can put a 255 on the wheel size the OP was asking about.
I run a 225 on a 9.5" wheel for my personal vehicle. Its just personal preference
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
redmaroz
Aug 16, 2015 11:40 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
