lug bolt pattern
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: lug bolt pattern
You measure across 2 studs like you were doing but you measure differently. From the outer edge on one stud to the center of the second stud will give you 4.75.
Small GM bolt pattern has always been 4.75". The large GM pattern is 5" found on pickup trucks and the larger model cars.
Ford and Dodge small pattern is 4.5"
UltRoadWarrior9
Sep 2, 2015 08:24 PM
