Help! I bought wheels that don't FIT!!!!
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
Ok, I bought a set of 95 camaro wheels and they won't fit. Do I need a wheel spacer of something? They are the 16' "blade" kind from the z28. The front ones won't fit b/c the inlay isn't as extreme as with my 92's 15's. Where would I get a spacer? Do I do any Grinding? Thanks, Nate
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Help! I bought wheels that don't FIT!!!!
I think you'll need a 1.5-2 inch bolt on spacers. Never ran 4th gen 16s myself.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Just a little bit of
would have found you the answer. This is one of the top 5 topics asked here. Yes you need spacers to fit 4th gen wheels on a thirdgen.
http://www.skulte.com/ sells them.
would have found you the answer. This is one of the top 5 topics asked here. Yes you need spacers to fit 4th gen wheels on a thirdgen.http://www.skulte.com/ sells them.
Engine: 3.1 V6 MFI
Thanks for the info, that site was a little expensive. I can get 4 2" spacers on ebay for 140.00 with free shipping. I apologize for the redundant post, I did a search and saw that people were using spacers but I wasn't sure how large and if it would be diff. for my 92 than for the other various 80's thirdgenner's etc. I just wanted to play it safe and start a thread of my own.
Lug Question: Should I use my stock lug nuts to put on the spacers and then buy 4th gen lugs for the threads coming from t he spacer? How can I torque down on the wheel spacers properly on the front? Will it hurt my brakes or wheel bearings to have someone hold down the brakes while I torque down on the spacer? Thanks guys!!
86IROC112
Sep 7, 2015 01:37 PM
kah992
Aug 19, 2015 02:55 PM
