cutting lowering springs??
Old Mar 24, 2009 | 05:59 PM
2fast4love's Avatar
i got pro kit springs on my iroc but it doesnt sit as low as i want it to. i was considering cutting a 1/4 of a coil or so any one have any exprince with this?
Old Mar 28, 2009 | 01:12 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Re: cutting lowering springs??
why not sell those and get the sportlines?
Old Mar 28, 2009 | 01:28 PM
bart91406's Avatar
Car: 91 rs
Engine: 383 290 cam aed carb
Transmission: th350
Axle/Gears: 4.10 ticking time bomb
There is absolutely nothing wrong with cutting coil springs, as long as it is done with some common sence.
Do not cut them with a torch, which seems obvious but you would be suprised. And do not try to cut them to lower it an extreme amount, as it well mess up suspension geometry.
I would not reccomend selling them to buy different springs, one problem with lowering springs is because a cars weight can vary so much, they can not sell a two inch lowering spring, they will be from 1 to 2, or 2 to 3 ,etc.
Some springs, like the Moroso drag sprin, reccomend trimming to desired ride height, so I would not let uneducated people to you "it is dangerous, I do not know why, it just is, blah blah"
I
Old Mar 28, 2009 | 05:58 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
You could do this just as easily. I'd lean towards keeping the prokit if you're just looking for a hair more drop. Trimming the prokit springs 1/4 coil at a time will also increase spring rate (stiffer)
Old Mar 28, 2009 | 07:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
because sportlines suck
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 26, 2015 03:32 PM
